Congrats!
Congrats!
1999 Z28. A4. Magnaflow catback and a lid. 60k miles.
My target. Still need some work. The first few rounds went into the wood post above the target. I should have took a picture of that. They'll have to replace it for sure.
'91 Firebird - LC2 3.8, 6776S Turbo, Alkycontrol, S60 Rear, ProBuilt 700
haha I had friends there yesterday shooting an EBR also
Matt -
2010 Boost Logic GT-R
1983 Ford Fairmont
If it's sighted in for 100 yards, it should be fine at 50 also. From what I've found, the 7.62's trajectory is relatively flat between 50 and 100 yards. There should only be a little bit of rise between 50 and 100. If you plan on keeping it any length of time, I'd invest in one of these: http://www.keepshooting.com/ak47-sks...ment-tool.html
That's not bad at all for your first time out at 50 yards. It's a lot harder than most would think. AK's aren't known for accuracy. They're designed for reliability and putting a lot of rounds at a target, so don't expect 4" groups at 100 yards with iron sights.
The main keys are sight alignment, sight picture, trigger control (squeeze the trigger, don't "pull" it. You want it to kind of surprise you when it goes off), and follow through. Master those and you'll be ready to take some tactical self defense courses.
1955 Chevy Bel Air, 327, 4 speed
2020 CCSB Silverado RST
Here is some ballistic info for you:
BC: 0.2400 (G1) Temperature: 73.0 degrees Cant Angle: 0.0 deg.
Weight: 124.0 grains Humidity: 73 % Sight-In Range: 200 yd.
Caliber: .311 Pressure: 29.92 in. Muzzle Angle: 8.466 moa
Sight Height: 2.00 inches Crosswind: 8.0 mph TargetSpeed: 0.0 mph
LOS Angle: 0.0 degrees Altitude: 25 ft. Target Angle: 90.0 deg.
Sect. Density: 0.183 Air Density: 0.0738 lb./ft.^3
Air Density: 96.5 % of Sea Level
Range Drop Velocity Energy Momentum Windage Lead Time Elevation
(Yards) (inches) (ft/sec) (ft-lbs) (lb-sec) (inches) (inches) (secs) (moa)
0 -2.00 2345.0 1514.0 1.2913 0.00 0.0 0.000 -----
25 0.00 2259.8 1406.0 1.2443 0.09 0.0 0.033 0.00
50 1.58 2176.3 1304.0 1.1984 0.35 0.0 0.066 3.16
75 2.70 2094.5 1207.9 1.1533 0.80 0.0 0.102 3.60
100 3.32 2014.6 1117.4 1.1093 1.44 0.0 0.138 3.32
125 3.41 1936.6 1032.5 1.0664 2.28 0.0 0.176 2.72
150 2.91 1860.5 953.0 1.0245 3.35 0.0 0.216 1.94
175 1.79 1786.4 878.6 0.9837 4.64 0.0 0.257 1.02
200 -0.01 1714.6 809.4 0.9441 6.18 0.0 0.300 -0.01
225 -2.56 1645.1 745.1 0.9058 7.96 0.0 0.344 -1.14
250 -5.90 1578.0 685.6 0.8689 10.02 0.0 0.391 -2.36
275 -10.12 1513.7 630.8 0.8335 12.35 0.0 0.440 -3.68
300 -15.29 1452.2 580.7 0.7997 14.98 0.0 0.490 -5.10
325 -21.49 1393.9 534.9 0.7675 17.90 0.0 0.543 -6.61
350 -28.81 1338.9 493.5 0.7372 21.13 0.0 0.598 -8.23
375 -37.34 1287.4 456.4 0.7089 24.68 0.0 0.655 -9.96
400 -47.19 1239.9 423.2 0.6827 28.54 0.0 0.715 -11.80
425 -58.45 1196.4 394.1 0.6588 32.71 0.0 0.776 -13.75
450 -71.22 1157.2 368.7 0.6372 37.19 0.0 0.840 -15.83
475 -85.63 1122.1 346.7 0.6179 41.96 0.0 0.906 -18.03
500 -101.75 1090.9 327.7 0.6007 47.01 0.0 0.974 -20.35
Nice! Very nice! What range is that?
1994 Yamaha YZF-750R / 1993 Honda CBR900RR / 1991 Kawasaki ZX-7 / 1992 Kawasaki ZX-7R / 1993 Kawasaki ZX-7 / 1989 Suzuki GSXR-750
I want a lever gun!
