Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: 1963 Harley Davidson Topper Restoration
    Club Sponsor 99SaleenSpeedster's Avatar
    Jan 2001
    Canton, MI
    4,467
    Default 1963 Harley Davidson Topper Restoration
    Below are a few photos of a project I worked on with my dad recently. It's the highest optioned Topper you can find and still has the rare windshield and storage compartment. Instead of painting it red as it was originally, we went with Ford Grabber Blue as we have another project from the same era we are working on that is the same color.
    First, some history on Toppers
    The Harley-Davidson Topper is the only motor scooter that the Harley-Davidson Motor Company ever produced. The Topper has a 165 cc (10.1 cu in) single-cylinder two-stroke engine mounted horizontally between the floorboards.
    The engine requires a premixed gasoline/oil mixture. The starter is a rope-recoil type similar to lawnmowers. Unlike most scooters with enclosed engines, the Topper's engine does not have a cooling fan.
    It was expected that the low, horizontally mounted engine would be cooled by air passing under the scooter, but some Toppers developed overheating problems. The engine uses a reed valve in its induction system. The engine powers a continuously variable transmission that includes a safety device that does not allow the scooter to move from rest at engine speeds higher than 1800 rpm.
    Final drive is by an exposed roller chain. The Topper has 5 inch internal expanding drum brakes on both wheels. The front brake is controlled by a hand lever with a parking brake lock; the rear brake is controlled by a pedal.
    The front body, front fender and floorboards of the Topper are made of stamped steel, and the engine cover and body are made of molded fiberglass.
    The Topper H was introduced in 1961 (sold through 1965) with a new alloy cylinder head that increased the compression ratio to 8.0:1, the transmission placed in a sealed oil bath, a reusable foam air filter, and revisions to the cylinder ports and air intake tube. A detuned version of the Topper was also available, with the power restricted to 5 hp (3.7 kW). This was advertised as the "Topper U."
    Sales lagged, and Toppers lasted just five years in the Harley line. It’s estimated that fewer than 3,000 were sold.
    A little rough, but original (other than refinished wheels) and expected being 52 years old.
    Club Member sardeanie's Avatar
    Oct 2005
    Watertucky
    4,382
    What a cool project. Turned out great! Grabber Blue was a good choice.
    Club Member 4Gas$'s Avatar
    Nov 2005
    Milan
    10,704
    Cool
    That is very cool! You guys did a great job on her.
    What are one of those worth, restored & unrestored?
    Club Member AutoRoc's Avatar
    Dearborn
    6,003
    Museum stuff right there, very cool Rick.
    Denny Villemure
    PSSSSSSST!
    10.85 @ 126mph
    Jan 2001
    Canton, MI
    4,467
    Quote Originally Posted by 4Gas$ View Post
    Thanks guys! They're not worth a ton, my dad just likes having some toys you don't see everyday. Id say it's worth $5,000-$7,000.
    Jan 2001
    Canton, MI
    4,467
    Jan 2001
    Canton, MI
    4,467
    The other project currently in progress is a 1958 Turf Rider IV golf cart..
    It will transition from a heavy electric cart, to a sleek and nimble gas cart. Moving to the 2006 Club Car Precedent underbody and chassis will certainly present challenges and require a lot of fabrication along the way, but it will happen.
    Most of the Turf Rider carts had 3 wheels, very few 4 wheel versions were produced before the company went out of business.
    This thing was rough...
    When trying to decide whether or not to restore it to original condition, we thought what fun would that be...
    With a little inspiration from this
    It went from
    To
    The donor cart
    It'll have some new, larger wheels and likely be lowered a bit.
    Jan 2001
    Canton, MI
    4,467
    Other not so common toys are a few Feather Craft boats. 2 1958 Vagabond II's and a 1954 Runabout. These are fun little boats.
    And
    This one was painted when he got it and he ended up leaving it that way..
    Club Member hangemhigh's Avatar
    Jan 2008
    Rivalry Czar
    12,271
    Very cool....Thanks for sharing!
    7,217
    Those are bad ass
