Results 1 to 9 of 9
Thread: nitrous limit
    Junior Member
    Mar 2011
    Highland Park, Michigan
    24
    Default nitrous limit
    what is a safe limit on a 87' ford 5.0 block filled(hardblok filler) to water pump holes, heavy main caps, arp studs throughout, line bored, stock nitrided crank, scat cap screw rods(I beam), crank has oil holes scalloped, forged flat top pistons w/ increased ring gap. balanced assembly. have between 100-250 cheater 2 stage.
    Club Member
    Rochester Hills
    5,137
    Good question. I've seen stock ones almost split in half with 150 shot.
    Club Member Beigg's Avatar
    Feb 2009
    I am here >x<
    5,376
    if you can control e-timing while using a progressive/launcher controller for the system, it should enable more nitrous capability compared to a traditional hitting system.
    From my experiences; Even if you built an identical engine, ymmv with the amount of spray it could potentially ingest before it lets go.
    Club Member AutoRoc's Avatar
    Dearborn
    5,986
    Send it!!!
    Denny Villemure
    PSSSSSSST!
    10.85 @ 126mph
    Club Member black88coupe's Avatar
    Feb 2005
    YES my shit is slow and NO you can't drive it!
    6,880
    Spray it til the block splits then step it down one jet size.
    Did the wizard ever get back to you about that brain?????
    Oct 2008
    at home with the family
    5,226
    Lmao
    Club Sponsor 347convert's Avatar
    Nov 2005
    Canton
    6,781
    I split mine with no shot lol
    It is Cylinder pressure and RPM, I feel like you can have 1 of those, But not both lol.
    I had a 306 with 150 shot and it loved it, I maybe ran 20 bottles through it. The only thing that broke was the top rings.
    The 347 I had broke in 2 with no shot, but I guess 11 to 1 and 7500 RPM will do that.
    Forum Member slow96hater's Avatar
    Mar 2008
    romulus, mi
    642
    We had a stock 150,000 mile 302 that lived really well with a 150 shot for a few years of heavy use (high school car, we sprayed at every stop light ) if I remember correctly the car ran 12.50’s.
    Forum Member MarkVIII93's Avatar
    Nov 2009
    Allen Park
    2,887
    Ls swap it...
There are currently 2 users browsing this thread. (0 members and 2 guests)
