Results 1 to 10 of 12
Thread: Pinion angle
    Aug 2005
    West Olive, MI
    502
    Default Pinion angle
    What is the maximum downward pinion angle I can use?
    28,361
    depends on suspension and use.
    Aug 2005
    West Olive, MI
    502
    1930 model A, 350/350.
    The rear is coilover with hairpin control arms. Assume the trans is installed level.
    Club Member dave89iroc's Avatar
    Taylor, Mi
    16,273
    race car, or street car?
    street car is ok to have 1-2 degrees down, but make sure that both ujoints have a couple of degrees on them(not strait), or they will not lubricate properly
    ASE Master Certified Technician
    Club Member Way2Slow's Avatar
    Feb 2008
    Clinton Township
    610
    Depends on transmission angle also!
    REAL RACE CARS HAVE 3 PEDALS!!
    Taylor, Mi
    16,273
    Quote Originally Posted by Way2Slow View Post
    he said assume the trans is level
    Aug 2005
    West Olive, MI
    502
    My understanding of pinion angle is the it should be the opposite of the transmission angle. The line continuing from each should be parallel. So if the trans is +2 degrees, the rear should be -2 degrees if the installed height in the vehicle of both parts are the same.
    The question is what is the maximum angle I can point the pinion downward?
    Taylor, Mi
    16,273
    Quote Originally Posted by fakessturbo View Post
    no real max, if the lines are parallel
    and it won't hurt if the pinion is down slightly more, as it will rotate up a little under power
    but IIRC, you don't want more then ~10 degrees in the joints, as you still need extra for axle movement
    Forum Member NVR2FST's Avatar
    Apr 2004
    1,832
    -2 to -2.5 is a good place to start.
    Feb 2008
    Clinton Township
    610
    I missed the trans was level, -2 to -4 will work without any problems.
