Thanks Joe. i found a good deal on a newer rear end but didn't want to alter a lot of things to make it work so I'll keep looking.
Ive been 8.20s for years at 3300 pnds with a built 8.8
For 1000hp the 8.8 will continue to perform all day lengthy. 33 spline axles and a reel is all you will need. A cover girdle would be awesome also.
For further information Call us: 61-414974062 Email And Address: info@sydneyelitelimo.com.au 28 Sunny Crescent, Punchbowl NSW 2196
limousines for rent | limo rental sydney | sydney car rentals
Have fast have you guys gone with c clips?
I've always thought with disc brakes the bracket would stop the axle from coming out but then have been told it can bind up and basically act as a wheel stop and turn you whichever direction
I've been wondering the same thing. I know NHRA rules say anything faster than 10.99 needs C-clip eliminators, and disc brakes do not out as an axle retaining device, but every set up I keep finding is expensive. I'm looking to run in the mid-10's. Anyone run that fast with c-clips?
I see what you mean. All different setups will cause different stresses. Any general guidelines on when to upgrade from 31's on an automatic car? My setup is going to be SBF, C4 (no brake) and probably ET Streets. Like I said, I think I'm fine for now, but I'd like an idea of when I'll need to start putting money into the axle. Any ideas?
