Page 10 of 13 FirstFirst ... 678910111213 LastLast
Results 91 to 100 of 122
Thread: Schwartz 1964 Chevelle Chassis Final Fix
  1. #91
    Oct 2006
    Troy
    4,274
    Quote Originally Posted by mikesfastss View Post
    Looks good, not sure how comfortable I feel running the battery cables right next to the fuel line.
    They're dead except when you start it...No biggie...I like to run the ground all the way to the engine......
    grr
  2. #92
    Oct 2006
    Troy
    4,274
    Well, I see PhotoFuket has screwed everyone now, unless you pay....
    Anyway, worked a little more on the wiring and have the plumbing all worked out for my Hydroboost. I also welded on a couple of -6 fittings to the powersteering reservoir. I took it all apart, blasted, painted and replaced all of the "O" rings while I was at it...
  3. #93
    7,220
    I used AN fittings on some auto projects. They are the way to go.
    What are you using for hose? The Russell lines are difficult to seal properly with PTFE inner lining.
  4. #94
    Oct 2006
    Troy
    4,274
    I've used these a lot. I do have the PFTE lines on the hydroboost,itbut I've also used those quite a bit and know the trick to assemble them..
    grr
  5. #95
    Forum Member JpMotorsports's Avatar
    Jan 2006
    Clinton Township, MI
    1,434
    Awesome looking car! Just read through your thread. Wow! Good luck with the rest of the project. It would look good next to my 67 SS!
  6. #96
    Club Member Krazybones's Avatar
    Aug 2005
    13,948
    Quote Originally Posted by JpMotorsports View Post
    John, mayb we should drive our 67s to Gary's house to visit and check this out.
    Maybe he will let me borrow his trans Jack for the 10th time so we can do your converter! I also need to pick up the gear oil...
    Dang I am a shitty son, right Gary?
    ****MATT*****
  7. #97
    Oct 2006
    Troy
    4,274
    Quote Originally Posted by Krazybones View Post
    Well, come by whenever you'd like...
  8. #98
    Jan 2006
    1,434
    Im in for returning the jack to him with our cars!
  9. #99
    Oct 2006
    Troy
    4,274
    WooHoo....It's alive - Got it running....
  10. #100
    Sounds good!
