Page 11 of 13 FirstFirst ... 78910111213 LastLast
Results 101 to 110 of 122
Thread: Schwartz 1964 Chevelle Chassis Final Fix
  1. #101
    Sweet. Nice lope!
  2. #102
    Oct 2006
    Troy
    4,274
    Finally finished with the engine compartment. I tried to hide all of the wiring. I am about 98% finished with the entire car, too - I went to install the door weather stripping and the body shop didn't quite paint enough under the drip rail. So, I scraped, sanded and primed where the weather stripping goes. I will go to the body shop and pick up a little paint to finish it, then I can put the last 2 pieces of weather stripping on. After that, all I need to do is install the seats and the car should be ready to drive...
    Here are a couple of pics of the finished engine compartment...The last pic is the Hydro-Boost and my dual master cylinder set-up.
  3. #103
    Gorgeous Gary!
    I'm practically a neighbor, I'd love to get a ride when it's done
  4. #104
    Forum Member JpMotorsports's Avatar
    Jan 2006
    Clinton Township, MI
    1,434
    Looks and sounds amazing!
  5. #105
    7,220
    That sounds very healthy!
  6. #106
    Oct 2006
    Troy
    4,274
    Finally back on the ground. I think all I need to do is put in the seats and do something with the speedo cable, e brake and license plate lights. Difference this time is nearly everything is hooked up permanently...
  7. #107
    Quote Originally Posted by grr456 View Post
    She's a work of art, Gary.
  8. #108
    Oct 2006
    Troy
    4,274
    Trunk has been completed and only one more seat and seat belts to go…….I had it running and ran it thru the gears. So, the new clutch, transmission and all the rest of the stuff is sort of working. Disconnected the battery and the engine kept running, so the alternator is working…Haven’t driven it yet…
  9. #109
    7,220
    What did you coat the trunk with? I need to freshen my Mustang's trunk up.
  10. #110
    Oct 2006
    Troy
    4,274
    I bought the actual correct Zolatone splatter paint and it didn't splatter very much. The reason I bought it is because you didn't need to clear it afterwards. Well, it didn't look right, so I just bought 2 cans of Duplicolor and redid it and it came out better. I then shot a nearly flat clear over it to protect it...
    Gary
