Page 75 of 78 FirstFirst ... 25657172737475767778 LastLast
Results 741 to 750 of 774
Thread: The ask Tin about audio thread
  1. #741
    Club Member yonson's Avatar
    Wixom
    266
    Quote Originally Posted by WhiteHawk View Post
    Ended up ordering an Oppo, too, BTW. It turns out Oppo is the ONLY Player to include decoded pre-outs for 7.1 surround sound, as well as balanced out for 2-channel. Plus it has a crap ton of cool stuff built in. That saves me from putting a separate decoder in the system, and will plug directly into the 6-Channel Rotel amp I bought from salvation army for $20 to run surround speakers. I thought the Oppo was steep when you first suggested it, now I think it is a deal. Thank you for the tip!
    Which one did you get? I've got a 105D and a 205. I was quite happy with the 105D and actually prefer the menu's etc... but the DAC and 4K capability of the 205 is well worth it...
  2. #742
    15,488
    Quote Originally Posted by yonson View Post
    I got the 205 (well, I ordered it at least). I liked the DAC with with digital coax and optical input, and I liked that it had 2 channel balanced XLR audio out which will be useful if I switch from a receiver which I have now to an analog pre-amp for 2 channel. If I end up wanting more power for the maggies having a receiver is pretty pointless anyways. all my digital can run through here including a bluetooth adapter. Plus I can run multiple outputs of this unit into my receiver depending on if I am watching a movie or listening to music, plus keep the surround channels separate. It seemed like a pretty complete package.
    They must be pretty good if you have both! Are you just running multiple setups with them?
  3. #743
    Wixom
    266
    I bought the 105D a couple years ago because I needed a good source with balanced out, I mostly use it for 2 channel stereo, but occasionally for watching movies, I have a separate PRE/PRO that is balanced in/out going to the amps. I have a 4K TV so once the 205 was announced I got in on the pre-order for it so that I could actually watch 4K content and was quite happy with the updated DAC in the 205. The 105D will be the source for the system in my shop once I get time to finish setting it up...
  4. #744
    15,488
    I think there is something wrong with me. I saw this ad on Craigslist. I absolutely, 100%, do NOT need this amp. But I still want to buy it. Does anyone ever experience this? Maybe we can get a support group or something.
  5. #745
    Wixom
    266
    Hmm I should list my XPA5 Gen 2 since it's just collecting dust...
  6. #746
    15,488
    So Oppo is shutting down. Their home page says they are going to be supporting for a while, but no new products. Better get them before they are gone! I love my 205, doing the surround sound straight out of the DVD to a 3 channel amp. It is pretty awesome.
  7. #747
    Forum Member H.O. Driver's Avatar
    Dec 2005
    Boyne City, MI
    813
    I am looking to build a home theater subwoofer. My Velodyne ULD-12 amp finally died and I thought to replace the amp but Velodyne doesn't have a way to repair and nobody local will touch it.
    So here is what I am looking, I got a 500w plate subwoofer amplifier, it is 500 at 4ohm but is 2ohm stable. I found a prefabricated dual 8" 4ohm dvc vented loaded enclosure that is rated 700rms but prewired to 1ohm. I will rewire to 4ohms but should I find the subs in a 2ohm dvc and run more power to them? For the amp, subs and box I will be at $400. Is there a better option for the price?
    The reason I am looking at dual 8s is just the low profile box. Should I go with a single larger sub instead? It will be for movies, music and gaming.
    Sent from my Pixel 4 using Tapatalk
  8. #748
    15,488
    Quote Originally Posted by H.O. Driver View Post
    Seems like you are in the range of something that is already put together for $400.
    - This REL is $699 but goes on sale all the time for $599 (this is what I paid and run, sounds awesome with movies or music). https://rel.net/shop/powered-subwoof...ie-ht/ht-1205/
    - Klipsch has their SPL subs on sale too. https://www.klipsch.com/spl-subwoofers
  9. #749
    Forum Member Rumblestrip's Avatar
    May 2011
    Royal Oak
    706
    Since you said "build" look at GR-Research:
    https://www.gr-research.com/diy-subwooofer-kits.html
    Also two is always better than one.
  10. #750
    Dec 2005
    Boyne City, MI
    813
    Quote Originally Posted by Rumblestrip View Post
    That was my logic, 16" of woofer in a 11" tall box .. I have read building is cheaper and gets a better result. The Velodyne rep said they would take $500 off a new sub for me since I was a loyal customer. However I would be in the $1000 range for a single 12".
