Page 18 of 24 FirstFirst ... 8141516171819202122 ... LastLast
Results 171 to 180 of 237
Thread: Turbo Mark VII Time
  1. #171
    Nov 2009
    I think I have a Prius stuck in my intake.
    1,828
    Whelp, I decided to toss the bits on to the motor to get an idea of what it'll look like. It's very...meh looking.
    BCN_5026 by Jason Bacon, on Flickr
    BCN_5027 by Jason Bacon, on Flickr
  2. #172
    Club Member AutoRoc's Avatar
    Dearborn
    6,003
    Thats pretty blingtastic I think. Keep pluggin away at it!
  3. #173
    22,841
    What's wrong with the look? I think it looks nice. What a massive undertaking this has been for a DIY'er, in my opinion. I can't wait to see it run.
  4. #174
    Nov 2009
    1,828
    These heads would really make it pop, at least to me.
  5. #175
    Nov 2009
    1,828
    So, I got home, opened the door and was scared by almost walking into a giant box! I got my S197 dash from Schoneck Composites today and let me say, the box weighs more than the dash and, the dash looks great!
    I also started fitting it into the car as well.
    31890996_2080171612307211_7952177221794267136_n by Jason Bacon, on Flickr
    31910149_2080213288969710_8725091685182210048_n by Jason Bacon, on Flickr
  6. #176
    Nov 2009
    1,828
    I started to actually get the dash in the car today. It is now the point were I need to cut the front of the top, so the whole dash sucks into the car another 1/2" or so, to match the shape of the windshield/firewall.
    BCN_5029 by Jason Bacon, on Flickr
    BCN_5032 by Jason Bacon, on Flickr
    Any section that I have cut, I have also saved, so I can tighten up any holes for the cage or the column once its 100% in place. That also gives me a reason to paint it, in more of a satin finish, more like a real car would have.
    I also made up the side brackets to hold the dash in. I used the factory dash structure to save time and, simplify the mounting to the car.
    BCN_5036 by Jason Bacon, on Flickr
    BCN_5037 by Jason Bacon, on Flickr
    Realize that the stamped steel is 2 pieces, not one... Time to burn it together.
    BCN_5043 by Jason Bacon, on Flickr
    BCN_5045 by Jason Bacon, on Flickr
    BCN_5048 by Jason Bacon, on Flickr
    I welded the pieces together, so I can cut off parts of the factory pieces.
    BCN_5050 by Jason Bacon, on Flickr
    Then, obviously, they get painted in satin black cage paint.
    BCN_5051 by Jason Bacon, on Flickr
  7. #177
    7,220
    That's a pretty cool twist. By the way, was the engine in the previous post a Kasse Racing engine? I like that you stayed SBF instead of LS swapping it.
  8. #178
    Nov 2009
    1,828
    It was the only dash that would clear the dash bar and still fit the look of the car. That was the main reason of getting that one but, I do like the dash on its own as well.
    The motor is form Hammer Head Engines.
    http://www.hammerheadperformanceengines.com/
    I'd rather put a Subaru motor into the car than a LS of any sort.
  9. #179
    Nov 2009
    1,828
    I played around in the garage for a bit and got the dash in the car. I still want to go back and make some small adjustments to make the top of the dash level but, I've had enough for the day. But, the dash is in the car and is no longer held up with tape.
    The next steps will be to close in what I cut out to clear the cage and then, paint it all a matte black to resemble the original finish.
    I also like, with the Lincoln console, not only do I have the factory window switches, it still allows room for me to add a radio with out having to reinforce the dash to hold it. I can make up a little section that will bridge the gap between the console and the dash to hold a radio, right behind the shifter. Hopefully, that will be fairly easy to do. Though, the next step is to get the windshield replaced and to finish the wiring.
    BCN_5060 by Jason Bacon, on Flickr
    BCN_5061 by Jason Bacon, on Flickr
  10. #180
    Nov 2009
    1,828
    Stuff and things.
    BCN_5078 by Jason Bacon, on Flickr
    BCN_5076 by Jason Bacon, on Flickr
    BCN_5072 by Jason Bacon, on Flickr
    BCN_5074 by Jason Bacon, on Flickr
    BCN_5069 by Jason Bacon, on Flickr
