Results 1 to 10 of 10
Thread: LS Alternator needed
    Forum Member Detroit Gearbox's Avatar
    Jan 2007
    Warren Michigan
    4,912
    Default LS Alternator needed
    2000 vintage but I'm sure this crosses over many years.... 5 3/8 housing Alternator.... pinching penny's
    Rich I’m pretty sure you will need to get the pin count on the plug and amperage to get the right one.
    Jan 2007
    Warren Michigan
    4,912
    Thanks... Ill check that
    Club Member capone's Avatar
    Apr 2008
    Clinton Township, MI
    2,524
    Rich I have a used one off of a early 5.3 - off of a Silverado I think it was off of a 2001-2002 . It came off of a running truck. You're welcome to it Free.
    28,361
    SMC may have some
    Jan 2007
    Warren Michigan
    4,912
    Quote Originally Posted by capone View Post
    That looks like it... I picked one up but the plug is different, it only uses 2 wires so I may be able to switch the plug.... Let me wok on it a little .... see if I can figure it out... and I was mistaken... mine is the larger frame one.
    Apr 2008
    2,524
    Quote Originally Posted by Detroit Gearbox View Post
    Okay it’s here if you need it I’m in Clinton township or I could drop it off at your shop. I need to talk to you anyway to see if there are upgrades I should make to my 4l80e before I do my LS swap.
    Sent from my iPhone using Tapatalk
    Jan 2007
    Warren Michigan
    4,912
    I guess I would rather install yours than change the plug... friend of mine had a half dozen alternators like this.... all with the later plug.... I wanted to check with him first... he does not have what i need.
    My vette with an automatic trans was throwing belts with a manual trans alternator on it. Clutch in alt is different for automatic and manual...something to be aware of.
    Jan 2007
    Warren Michigan
    4,912
    Thanks Capone! I owe you.
