Results 1 to 10 of 20
Thread: 1989 IROC-Z Vortec 4200 Turbo
    Club Member AutoRoc's Avatar
    Dearborn
    6,004
    Default 1989 IROC-Z Vortec 4200 Turbo
    $14,000 obo. Motivated seller! Located in Dearborn, Michigan 48124
    1989 Camaro IROC-Z Convertible. 76k miles on cluster. Odometer no longer hooked up after engine swap. 2006 Vortec 4200 Engine. Custom oil pan. 4L60E with Sonnax kit. Custom Torque Converter 3000rpm foot brake. Moser 12 Bolt Axle, Eaton HD Diff. LS1 Rear disc brakes. Complete Spohn Rear Suspension. 3" Steel Driveshaft 1350. Snow Methanol Stage 2 kit. 70mm Precision Turbo. PT1000 A/W Intercooler. Big Heat Exchanger with puller fan. Remote Mount Meziere Water Pump. Walbro 340 pump, factory fuel lines. Digital fuel pressure gauge. Boost gauge lights up only when in boost and methanol kit is flowing. Champion Aluminum Radiator w/ 17" Puller Fan. Complete rewire with American Auto Wire Fuse Panel and wiring. Cruise control. Bluetooth Radio. Corbeau Seats. Harnesses. Chromoly 8pt rollbar, welded through the floor to subframe connectors. Door bars cut for swingouts. Mojave Heater. Simmons 3pc Wheels. 315/35/17 M/T Drag Radials. Dyna tech 4" muffler + Dynomax VT 3" muffler. This car right now makes 7psi with the full quiet exhaust system. Roughly 400hp. Twist the knob, open up the exhaust, and it makes 500hp at 10psi, 600hp at 15psi.
    The Bad. Convertible Top has a few rub holes but functions great. Paint has a few scratches, urethane body parts have some cracks. It's a good base body for a complete vinyl wrap that the new owner can complete.
    Club Member 1fstfox's Avatar
    Dec 2006
    Napoleon, OH
    2,177
    I didn't think I'd ever see the day! I remember following the build on this back in the day. How's it looking now that it's finished up?
    -Ryan-
    91 Slow'noma - 14 Cruze Diesel - 16 Ram 1500 Limited
    16 KTM 1290 SuperDuke R - 18 GasGas TXT300GP
    Dearborn
    6,004
    Well I said I would make it look good after it ran good... It's been running great for 10 years in it's current iteration but I can't see myself spending thousands for a vinyl wrap. Too many toys and this one just keeps accumulating scratches from being in my small garage. It's posted on a Vortec 4200 swap group that I stumbled on recently. There are quite a few people that are enamored with these oddball engines.
    Dec 2006
    Napoleon, OH
    2,177
    For sure! I love it, being different while also performing well! I considered using one in my Sonoma after you started the build. I even had the core out of my old Envoy I could've used as a starting point. But I already have 2 5.3s in the garage waiting for it.
    -Ryan-
    Elected Club Official
    Sep 1999
    "The Place to Be"
    35,656
    Boooooo
    Club Member Krazybones's Avatar
    Aug 2005
    13,948
    Damn this is a cool car...
    ****MATT*****
    22,841
    Good luck, such a cool car!
    Yeah I remember my jaw dropping seeing that run at the track. GLWS Denny!
    Club Member cjmatt's Avatar
    Jan 2006
    your mom
    15,088
    Whatd this thing ever end up putting down?
    Matt -
    2010 Boost Logic GT-R
    1983 Ford Fairmont
    Forum Member ultradriver10000's Avatar
    Jun 2015
    Clarkston
    908
    Any more pictures or videos? That is pretty sweet.
